Special handling package
I've got an 04 Intimidator with the FE4 suspension (I guess this is the special handling package)
but I would like to change the struts to KYB AGX adjustable and Eibach springs, Does anyone know if the differences are between FE2 (Std) and FE4 (SHP) are just spring rates and shock valving or are there physical (mounting position, length, etc.) differences? Any input would be appreciated. Thanks Aaron |
RE: Special handling package
The mounting is the same, but the FE4 struts are a special 4 valve shock. Not sure about the springs. I put Monroe's on my '01 SS LE and regreted it. As far as I know, the KYB/Eibach combo is as good as anything out there
X2. This is a great combo.
