had problems but fixed it i hope
well last year before i parked the monte was having a problem
my CEL was on so i got a new MAF flow in it fixed the problem for a couple days then the CEL came back on.............did some research on the net and something came up that might be the PCV VALVE? WTF LOL
so today i bought a new one went to the car and put it in ......started the car and CEL is gone ???????
could that be the problem? and its fixed now?
RE: had problems but fixed it i hope
[align=center]Hi Manny,[/align][align=center]A bad or clogged PCV Valve can throw codes : ([/align][align=center]Have you ever used Sea Foam in your engine ?[/align][align=center]I hope the PCV valve was your prob.[/align][align=center]Good Luck & EnJoy your Awesome `Monte : )[/align][align=center]`Space[/align][align=center][/align][align=center]Mod Wiz Kidd, and several member's really believe[/align][align=center]in this product[:-][/align][align=center]SEA FOAM MOTOR TREATMENT for Gas Engine Applications
100% Pure Petroleum
Use in All Engines in All Seasons
2 Cycle, 4 Cycle, and Diesels
Treats 3 Critical Areas: Gas Tank, Fuel Systems, and Crankcase
[ul][*]Cleans fuel injectors[*]Cleans carburetor jets[*]Cleans carbon[*]Stabilizes fuels[*]Upper cylinder lube[*]Removes moisture in fuel[*]De-icer
Frees sticky lifters
Frees sticky rings
Removes moisture in oil
Cleans P.C.V. systems
Cleans catalytic converter odors
Oxygen sensor safe [/ul]
How Many Mechanics Use SEA FOAM
In Tune-Up of 4 Cycle Gasoline Carbureted or Fuel Injected Engines
Autos, Trucks, and Tractors
[ol]
With engine warm, slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.) This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon. Turn ignition off. Restart engine after 5 minutes. If severe carbon build up is apparent, use more Sea Foam as previously directed. Make sure exhaust is well ventilated when using Sea Foam in these various ways as fumes will be extreme for a short time.
Pour 1/3 to 1/2 pint into oil crank case to clean rings, lifters, dirty parts and remove moisture.
Pour 1/3 to 1 full pint into fuel tank to clean injectors, carburetor jets, fuel lines and remove moisture.
Immediate Results: Smoother idle, increased R.P.M.'s better throttle response and improved performance. See label on can for detailed results for use in each area. [/ol]
FUEL TANK, CARBURETOR, INJECTION and OIL CRANKCASE. For Peak Performance, Use SEA FOAM Every 2,000 to 5,000 Miles
[ul][*]A 100% pure petroleum product for use in all gasoline and diesel type engines, both 2 and 4 cycle. OXYGEN SENSOR SAFE.[*]Cleans dirty engine parts internally by removing harmful gums, varnish and carbon. WORKS AND PERFORMS INSTANTLY.[*]Removes moisture from oil crankcases and fuel tanks.[*]Stabilizes and conditions fuels. Use for engine storage.[*]Cure hesitations, stalls, pings and rough idle due to carbon buildup.[*]Helps pass emissions test. EPA Registered. [/ul]When Used Thru Injection or Carburetor[*]Cleans carbon build up[*]Cleans intake valves and pistons[*]Gives smoother idle[*]Cleans catalytic converter odors[*]Cures hesitations and pings[*]Restores power and pickup[*]With warm engine running, SLOWLY poor 1/2 pint through carburator, throttle body or direct manifold vacuum line that will feed ALL CYLINDERS. Possible sources are P.C.V. valve or brake booster line. Turn ignition off. Restart engine after 5 minutes. Be sure exhaust is well ventilated. Fumes will be extreme for a short period of time.[*]For use in injector cleaning machines, use 50% SEA FOAM and 50% fuel.[*]Fill d
100% Pure Petroleum
Frees sticky rings
[ol]
Below is a MCF Link with posts about
SeaFoam
[:-]click link below
[align=center]Hi Manny, U R Welcome : )[/align][align=center]I never heard of SeaFoam until I was on the MCF,[/align][align=center]and then I researched it, & talked to several[/align][align=center]Certified mechanic's. They swear by this product[/align][align=center]for all engine type's.[/align][align=center]Do your own research, and no..., I'm not gett'in[/align][align=center]a commission from them I wish : )[/align][align=center]You have a SuperSuper Look'In Monte, and I know[/align][align=center]that you want it to be the best it can `be : )[/align][align=center][/align][align=center][:-]
Where to Buy SEA FOAM
Sea Foam is not sold online, but we would be happy to help you locate your nearest dealer. Please email us your address at customerservice@seafoamsales.com.
SEA FOAM can be found in many of the following auto parts stores:
ABC Auto Parts
Advance Auto Parts
Auto Value
Bumper to Bumper
CARQUEST Auto Parts
NAPA Auto Parts
O'Reilly Auto Parts
Parts Plus
PEPBOYS Auto
Pronto Auto Parts
Many independent auto parts stores also carry SEA FOAM products. Please contact your local auto parts store to see if they carry SEA FOAM products.
[/align]
ABC Auto Parts
Advance Auto Parts
Auto Value
Bumper to Bumper
CARQUEST Auto Parts
NAPA Auto Parts
O'Reilly Auto Parts
Parts Plus
PEPBOYS Auto
Pronto Auto Parts
[/align]
the code i cant remember .but it was causing teh MAF. beeing bad.......and then i was told to fix it and it was fixed when i was doing the research it said to try and put in a pcv or check it ..........so i did and i turned the car on and CEL is gone..........
if a pcv was all i need it i think thats all
