Rotor replacement
Old 11-05-2011, 04:47 PM
I'd like to see it too because Ive never see any type of screw holding them on but there is a washer type lock on one of the studs.
Old 11-05-2011, 05:02 PM
ChevyWhirlwind's Avatar
Looks like this and it's stripped...... http://www.filtsai.com/accord/brake_...tor_screws.jpg
Old 11-05-2011, 05:22 PM
oh, that's weird, never seen that before to be honest, can you drill it out? looks like those would have to come out
Old 11-05-2011, 06:29 PM
Zen's Avatar
Zen
Zen is offline
Seen these a lot.You'll either have to unscrew them with a big phillips or torex looks like a philips .or you can drill them out you don't need to reuse them.most of the ones i delt with i ended up drilling them out.
Old 11-05-2011, 08:05 PM
Originally Posted by ChevyWhirlwind
I see a small screw like thing inside one of the rotor holes could this be holding it? It looks like a torque screw. But it's stripped a little.
You can drill them out. You don't need to reuse them..
Old 11-07-2011, 09:32 PM
yea thats not the exact pic of rotor. But mines are stripped. Any ideas how to take it out if stripped?
Old 11-07-2011, 09:51 PM
Just drill them out you don't need the set screw ..
Old 11-07-2011, 09:56 PM
So like use a center bit to drill it out? I tried to drill it out and the phillips head pattern is shave off completely leaving a groove. I youtubed it and it sais use a Centerbit to drill inward and then drill the screw out.
Old 11-07-2011, 10:08 PM
Drill the head off to remove rotor, the screw is to hold rotor on the factory line..
You don't need the screw..Just install rotors with out the screw..
Old 11-07-2011, 10:36 PM
Will do thanks alot!!
Sagacious Sam
09-26-2014 09:15 PM
04 Intimidator
06-08-2008 10:51 AM
PsuBrock
05-31-2008 06:33 PM
sorcier11
07-20-2007 02:40 PM
BeachBumMike
03-04-2007 03:44 PM
Quick Reply: Rotor replacement
