Rotor replacement
Rotor replacement
Ok, now I'm actually in the process of changing my rotors. I can not seem to remove the two bolts in the back of the caliper bracket.
Do you guys have any ideas how I can easily remove these?? Help fast car up on jack currently only iPad now haha.
I had to sit in the wheel well to get as much pressure on it as possible, it should give, be careful not to snap the stud
sorry, the rotor should come right off once you have the caliper bracket off, try hitting the side of it with a rubber mallet or something to break a rust bond or something that may have been created
