Rotor replacement
Old 11-05-2011, 02:20 PM
ChevyWhirlwind's Avatar
Question Rotor replacement
Ok, now I'm actually in the process of changing my rotors. I can not seem to remove the two bolts in the back of the caliper bracket.
Do you guys have any ideas how I can easily remove these?? Help fast car up on jack currently only iPad now haha.
Old 11-05-2011, 02:28 PM
heat it up or use wd40 and let it soak a little.
I had to sit in the wheel well to get as much pressure on it as possible, it should give, be careful not to snap the stud
Old 11-05-2011, 02:56 PM
Thanks man I finally used strength and got it. Now my rotor isn't coming off. Is there another bolt or something? Shouldn't it slide right off?
Old 11-05-2011, 03:19 PM
I see a small screw like thing inside one of the rotor holes could this be holding it? It looks like a torque screw. But it's stripped a little.
Old 11-05-2011, 04:14 PM
sorry, the rotor should come right off once you have the caliper bracket off, try hitting the side of it with a rubber mallet or something to break a rust bond or something that may have been created
Old 11-05-2011, 04:24 PM
Ok does it matter if I have hub rings on my hub??
Old 11-05-2011, 04:27 PM
are they in front of the rotor? that may be what's keeping it on there
Old 11-05-2011, 04:28 PM
look here:
How to install hub rings
in this one it looks like it's keeping the rotor on there
Old 11-05-2011, 04:36 PM
Yea just got it off and still no movement.... I'm getting fed up. I swear it's this little rotor screw in there. And that's why I can't move it
Old 11-05-2011, 04:38 PM
do you have a pic? I've never had a screw in any rotors I've done
Quick Reply: Rotor replacement
