-   -   Resetting Tire Pressure & Oil Change Monitors (https://montecarloforum.com/forum/monte-carlo-repair-help-8/resetting-tire-pressure-oil-change-monitors-1018/)
c1benny Nov 1, 2005 04:26 PM
Wondering if anyone knows how to reset the oil change and tire pressure monitors without using the factory radio on a 2003 monte. I am going to replace the head unit, but still have these outstanding obstacles that need to be taken care of before doing so.
Thanks for the help!
mickey Nov 1, 2005 04:34 PM
RE: Resetting Tire Pressure & Oil Change Monitors
due a serch for it on here there is tons 0of info on here for it
chevy_jj Nov 8, 2005 01:22 AM
the only way to reset them otherwise is to use a gm tech 2 scanner that the gm shop has. not available to the public. you could change the radio but when you change or rotate tires and change oil you would have to take it in to have it reset. if your dealer mechanic is nice enough they may do it for you.
z34phoenix Nov 10, 2005 12:06 PM
go to mymonte.com we have tech articals over there and they cover the procedure for you to do it
