Reset Oil Change Message
I just put an aftermarket deck to replace the stock 2001 monte ss deck. It hasn't happened yet but when the oil change message pops up, how do I reset it now?
They installed a special module to let the deck work with the monte. Also, the stock deck is completely out. |
with key to on, press the gas to the floor three times.
Never done it before, but i've heard about the gas to the floor 3 times thing........
Awesome, is there a list somewhere online with a list of these manual reset actions?
Thanks |
have a 02 and to reset that it is done threw the radio. controls
your low tire .alarm, alll your settings are threw the radio. also have heard you can reset the oil life bye pressing on the gas peddle. dominic |
If you own the owner's manual, the procedures to do everything on the car with and without the radio is listed.
x2. i used the gas pedal method, worked for me. the manual (i think?) says it is supposed to chime to confirm, i got no chime but the light was off. ehh.
I used to have a pdf of the owners manual, but it looks like I miss placed it. Where can I find it? Does anyone know?
I know you can buy one at the Chevy dealer...an actual original copy. But have know idea how much..
