low tire pressure
Old 07-16-2009, 11:41 PM
01-ON-AIR's Avatar
Default low tire pressure
okay so im sitting on air and every time i lower the car this stupid warning light comes on. i have the tire pressure montoring system!
any way to permently bypass or get rid of this? its been reset lots of times and still the same even the guys @ the local garage have nothing.
anybody? or is this a lost cause...
Old 07-16-2009, 11:48 PM
Enzo354's Avatar
STILL SLOW
If it bugs you that much just flick your light switch on and off 3 times and reset it everytime it comes on.
Old 07-17-2009, 12:20 AM
01-ON-AIR's Avatar
nope, i would like a permenant fix
Old 07-17-2009, 12:22 AM
01-ON-AIR's Avatar
and that would be every time i drive the car
Old 07-17-2009, 10:08 AM
RickAKATed10's Avatar
Photobucket
Are your tires actually low or is it "malfunctioning?"
Old 07-18-2009, 01:14 AM
when the car is lowered it is changing the position of the sensor, the system thinks there is a flat.(or 4)
Old 07-18-2009, 01:20 AM
Enzo354's Avatar
STILL SLOW
Mabye someone could reprogram your pcm for you.
Old 07-18-2009, 10:10 AM
01-ON-AIR's Avatar
yep, every time i lower it ( its on air bags ) the sensor goes . its got to be something with the cars hieght. not the tires.
maybe when i get my new pcm from milzy, this might be something they can remove...
any other options guys would be helpfull
Old 07-18-2009, 11:55 AM
Enzo354's Avatar
STILL SLOW
There has to be a fuse for the tps, but im just throwing ideas out here.
Old 07-18-2009, 04:22 PM
jaws2008's Avatar
GOT SPL
not realy related to this issue but when i get my tires rotated it says i have low tire pressure. but i did have my fronts set at 35 and backs at 37.5 but its only to come on when there is 11 PSI differnce and it wasnt.
montejass
FWD Tech Guides '95-'07
42
09-22-2021 10:19 AM
big green dog
03-14-2012 02:56 PM
amberblk00
09-12-2007 03:03 PM
turner_dtp
06-18-2007 09:20 PM
keghead40
07-19-2005 12:13 AM
Quick Reply: low tire pressure
