Replacing spark plugs
I have a 2000 monte carlo ss .
I want to replace the spark plugs but the plugs on the back side of the motor are hard to get to . What is the best way to remove them? Any help would be appreciated. |
RE: Replacing spark plugs
my suggestion is get someone with a skinny hand because i was trying to change spark plugs on my malibu ls and i had the same problem but then i got my son to do it
SMALL HANDS OR NOT ITS A BIT** IVE DONE IT. THE BEST WAY IS TO PUT IT UP ON A LIFT AND REMOVE THE FIST SECTION OF ESHAUST FROM THE MANIFOLD AND THEN YOU NEED AN ANGLED SOCKET WITH EXTENSION OTHER THAN THAT ITS EASY
