Replace the wiper switch...
Old Feb 4, 2009 | 12:46 PM
OVRPWRD's Avatar
Default Replace the wiper switch...
So my daughters '97 Monte LS wipers stopped working. It was really cold w/ice on the windshield and she turned them on.[sm=headbang.gif] Of course they didn't move and then she said some smoke came from the turn signal lever.(I think she left them on but would not admit it) So 2 questions...
1. Is it the switch?
2. How do I change it?
I tried search with no luck.
Thanks for any input.
Old Feb 4, 2009 | 01:03 PM
Default RE: Replace the wiper switch...
could she have blown the windshield wiper motor?
Old Feb 4, 2009 | 01:06 PM
Hi Kevin, and Welcome to the Monte Carlo Family Forum.
Your daughter is fortunate to have a father that cares
Please be patience & Hopefully one of our MCF Expert
Members/techs will be able to assist you with your problem.
Keep checking back to see who post on your problem
Below are a few links that you may want to check `out
to give you some indication of what you may encounter
resolving your problem.
Good Luck from `Space
Click on the below links
1997 Chevrolet Cavalier wiper motor failure [ CarComplain...
You are not logged in. Log in My Account | Sign up Logout ... 1997 Chevrolet Cavalier accessories - exterior problems: wiper motor failure ... 1997 Chevrolet Monte Carlo, 1997 Chevrolet S-10 Pickup, 1997 Chevrolet Silverado, 1997 Chevrolet Suburban ... Make sure everything is lined up ok and that they are working. ...
www.carcomplaints.com/Chevrolet/Cavalier/1997/ac... - 20k - Similar pages
http://www.carcomplaints.com/Chevrol..._failure.shtml
2002 Chevrolet Monte Carlo Wiper
Help with wiper problem on 2002 Chevrolet Monte Carlo and free tech ... need to replace wiper motor need to replace wiper motor module on 1997 camaro more. ... Wipers My wipers on my 1966 chevy super sport convertible do not work I have ...
www.fixya.com/search/p695555-chevrolet_2002_mont... - 39k - Similar pages
Old Feb 5, 2009 | 04:56 PM
OVRPWRD's Avatar
ORIGINAL: chibiblacksheep
That was my 1st thought until I talked to our mechanic at work.(comercial roofing contractor)
The smoke came out of the lever... inside of the car. The motor is outside, highly unlikely the smoke came thru the firewall. Plus the washer squirter stopped too.
Old Feb 6, 2009 | 08:29 AM
I just don't see how by using your wipers on ice, there would be stress on the lever, doesn't that just send the signal outside to the motor and that would have all the stress?
Old Feb 15, 2009 | 04:40 PM
OVRPWRD's Avatar
she didn't use them ON the ice. They were frozen to the glass. When she turned them on, they didn't move and eventually smoke came out of the lever.
NowI just need to find out how to get at the wiper switch... not the lever, the switch which is inside of the column with all the wires attached.
Has anyone had their column apart?
Dstevens
Feb 23, 2013 01:38 PM
Chris s
Jan 29, 2013 11:11 AM
johnniep
Jan 25, 2012 01:13 PM
04chevyboy
Nov 10, 2011 07:39 PM
jims875
Feb 5, 2008 07:32 PM
