quick simple question
im about to do a tune up on my 96 monte, its got the 3.4 DOHC
my question is what spark plugs does this engine run best on......
ive always stayed away from platinum plugs but i also usually only work on my 92 bronco 5.0 which loves autolite coppers an missfires like a **** on platinums but from what google gave me alot of people have been putting some kind of platinums in these cars
so if you could just point me in the rite direction an give me a brand and style of plug most of you guys run id greatly appreciate it
TTT
was using search but the only thing im finding is that the platinums seem to have a problem with the "puck" falling off after a bit of time......was looking at some iridiums yesterday but im being told to gap at .045, the underhood sticker says .060 an the iridiums are non gappable cause youll break the tip off, the coppers are still the cheapest......but cheap isnt always better
im also being told to use platinums but ive had very bad experience with them.....would like to have a few members with some input before i go threw removing the plenum just to put some plugs in that are gonna fail me an make me do this all over again in a few days
i steer clear of the stealership......i recently changed out my crank sensor an needed a crank position relearn procedure which they charged me $300 just to plug into the car an push a couple buttons....took the tech like 10 mins an cost me a fortune thus the reason i do all my own work, then i know its done as cheap as possible while still being done the proper way.....
Wyotech and 10yrs on job experience helps......but sometimes it helps to hear from other experienced techs too, you can never stop learning
well i dont hate them i just wont let them work on my vehicle ever again, everytime i do they bend me over with no KY....i do however have a long time friend that works at the parts desk of the same dealership an he gets me good deals on parts so i geuss im saying if you do the work yourself an just use them as a parts source they are alright
