PCM Location
00 MC/SS
Where did they hide the PCM? [:@] Thanks! |
RE: PCM Location
ORIGINAL: scortch 00 MC/SS Where did they hide the PCM? [:@] Thanks! |
RE: PCM Location
The PCM is located in your airbox....
RE: PCM Location
Airbox, why didn't I think of that!!
That would have been the last place I looked. Looked everywhere else, even in the wheel wells! Thanks montejass, greatly appreciated! |
RE: PCM Location
Damn! If I had seen this one a little earlier, I could have been the savior. The only reason I know that is because when I changed the air intake, the new one had a mount for the PCM. I'm late I know, but I still had to throw my piece in there. You guys know how I am. Ahhaha.
RE: PCM Location
hey is it in the acual air box or is it mounted to the bottom of it?
I havent tore mine apart that much to find out yet LOL might have to do that if is ever quits raining over here |
RE: PCM Location
It is mounted in the bottom of the actual air box assembly. The airbox will come apart in two places. The front comes off to service the air filter. It also will come apart in the middle so that you can gain access to the PCM.
RE: PCM Location
kool thanks somthign i need to think about LOL
I knew it was there just wasent sure where yet |
RE: PCM Location
the PCM is the thing that controls the Traction control, right? Or is it the brain of the car?
RE: PCM Location
It's your cars computer... or brain... PCM stands for Powertrain Control Module.
Yes, it is programmed to control your traction control also. |
