P0420 Code Issue
Old Feb 20, 2013 | 02:50 PM
02CHEVYMONTESS's Avatar
milage has been fine. and the shop i took it to before and the code reader from shop an dthe one i have says its cat and sensors for that code and so did a chevy dealer. that is why i changed the parts.. now it pops up again.
Old Feb 20, 2013 | 02:51 PM
maybe ill have to get a new cat and see what happens.
Old Feb 20, 2013 | 02:52 PM
any links to a place i can get a new one and not pay tons of cash for one?
Old Feb 20, 2013 | 03:03 PM
Tons of cash is the only way to get the OEM quality one.
You can have an exhaust shop verify that the cat is not bad, and just get your PCM tuned to remove the P0420 code (since I run a high-flow cat, I have my code deleted)
Old Feb 20, 2013 | 05:27 PM
I found a site that i can buy a pcm with the code removed.
Old Feb 20, 2013 | 05:43 PM
Silver SLP's Avatar
I had the EXACT same code come up after I had my new exhaust put on. About 9 months later too, no code before. Get yourself an "O2 defouler". I'm almost 100% positive this will fix it.
Just type "O2 defouler" in ebay
Old Feb 20, 2013 | 05:47 PM
ok . I dont have the room for that though.or would it just be real tight
Old Feb 20, 2013 | 05:49 PM
Silver SLP's Avatar
It just goes in the same hole as the O2 sensor. Then the O2 sensor plugs into the other end. Think of it as an extender, cause that's all it is
Old Feb 20, 2013 | 05:50 PM
ok i only have maybe 2 inches at most where my sensor is ... ill prob just buy the one u sent me a link to
Old Feb 20, 2013 | 06:09 PM
Silver SLP's Avatar
Yeah, it was a tight fit but it's a lot cheaper than the OEM cat. Just be careful going into driveways and things like that because it does hang down a little lower. I never had a problem.
