P0420 Code Issue
I have a Monte SS, 2002 146k miles. I got error code 420. I have replaced front and rear o2 sensors, cat, resonator. I have no clue what other things may cause the error. Any thoughts?
It could also be a variance of types of gas....
from one gas station to the next....Do you fill up at the same gas station all the time?
Maybe for test purposes try a higher octane and see if that doesnt fix the issue....
Or replace bank1 O2 sensor.... (Thats the one before the cat)....
It could be that the o2 sensor got contaminated.... via oil, antifreeze, etc....
I fill at same station. I do use seafoam additive but not often. I have already changed the o2 sensors. Also after i changed the rear sensor it went away immediately, but after a month now it came back
I work at the place that has the station I know the supplier personally. I donot believe its a fuel issue though. I found something about a canister?
jking
