P0404 engine code
I have an engine code P0404 showing up on my 2002 Monte Carlo. I replaced the EGR valve but this did not fix the issue. Please help! I am getting almost no power under load. Very slow accelaration.
RE: P0404 engine code
ORIGINAL: king2805 I have an engine code P0404 showing up on my 2002 Monte Carlo. I replaced the EGR valve but this did not fix the issue. Please help! I am getting almost no power under load. Very slow accelaration. |
i would take it in but off hand i was thinking that is sounds like apluged Cat. when they plug up they will kill power and also you will notice the car will not run very well at idel ethier.
good luck |
I am with Mickey on this one. We just had another member yesterday with the same type of problem. Good news is, it should be covered under warranty. 8 years I think.
Keep us posted.. |
| All times are GMT -5. The time now is 07:47 AM. |
