P0300
I started up my Monte this morning to go to work and immediately noticed a vibration caused by a misfire. The P0300, random/multiple cylinder misfire code is what I got when I used my scanner. I noticed a slightly off sounding exhaust last night, but nothing like a misfire. The most recent thing I did was repaint the front bumper two days ago. I checked three things, the PCM, spark plugs, and vacuum lines. I have a PCM from ZZP, and I checked the connectors to it. I found dust from the painting process. I cleaned them with electronic connector spray, and plugged it back in. This didn't solve the problem. I also tried replacing the aftermarket PCM with the original. Still misfires. The next thing I checked was the two vacuum lines coming off the throttle body. The merge for the two hoses was cracked so I tried wrapping it in tape and zip ties. That didn't work either. I don't suspect that to be the problem though, because the two things the vacuum lines feed are the evap purge, and fuel pressure regulator. The engine will smell like unburnt fuel while running, and won't stall. So I don't think fuel is the problem. Next, I checked the park plugs. They are copper plugs only about 3,500 miles, and looked fine. Slightly lean maybe. The gap hadn't changed, but I regapped them anyway, from .065", to .060" Does anyone know what the problem could be?
P0300 can be a real pain as there are so many possible causes. Best bet is to break out the scan tool and take a look at the sensors to see if you can determine anything from that.
If it truly is randomly jumping around, a single fouled plug likely wouldn't be the cause. An ICM issue could do it, as could a small vac problem as you noted. Could also be a MAF or EGR issue, fuel pressure, etc. You can narrow it down more looking at the data though. |
(Post 716388)
It sounds like you have a fueling issue. What's your MPGs been like lately?
Just for reference because I dont know if this will help any but on my 05 SC I have the EGR removed and as for the IAT sensor.. I have messed with that thing so much, moved it around 5-6 different spots in my intake, accidentally left it unplugged, accidentally left it just hanging on the side of the intake. Never had any issues with those two..
Fun fact: if the iat sensor is unplugged, your car will think its bringing in -38*f air and youll foul your plugs.. Lol learned that one the hard way. |
(Post 716483)
Originally Posted by WolvenScout
(Post 716481)
They said the main cause was the catalytic converter. The cat on the ZZP downpipe I've had for only three months definitely went. Chunks of the thing fall out when shaken. So I took the car home and took it off.
Taking off the cat may have fixed the extreme symptom, but there is still another issue to fix. The mechanic also said that the IAT sensor and EGR may be causing the misfires. He mentioned the IAT sensor because I had the cover of my CAI off, which shouldn't make a difference, since the CAI is taking in ambient temp air anyway. The EGR was deleted, and the car functioned fine that way, so I don't believe that to be an issue. Now that your cat is off, you should be able to get a mechanic to actually diagnose the issue. I'd definitely suggest parking the car until you can do that so you don't damage the engine anymore. If you've got a dead cylinder, the walls are getting washed down from the raw fuel that isnt being combusted. Itll also throw off the O2 readings as you're dumping lots of straight air into the exhaust which will globally impact fueling for the other cylinders. Although idk how, since it's the stock computer. Should I let it idle and lean out since the computer uses more fuel for startup? |
(Post 716486)
The last I recall it was 19mpg, which has been normal. The car smells like unburnt fuel when I run it, and it won't stall out.
The unburnt fuel smell is what concerns me most. Its clearly dumping a ton of raw fuel to burn up a cat that quick. I'd imagine it's a lot more noticeable now without the cat - before it was probably burning some of it up inside the exhaust. |
(Post 716488)
That sounds about right with the EGR delete. TBH, I'd probably hook it back up once you get the problems fixed as it will improve the gas mileage. If I remember right, you've got a NA L36, so there's really no gains to be had by deleting it.
The unburnt fuel smell is what concerns me most. Its clearly dumping a ton of raw fuel to burn up a cat that quick. I'd imagine it's a lot more noticeable now without the cat - before it was probably burning some of it up inside the exhaust. I didn't delete the EGR for any gains really. I just wanted the oil vapor, carbon, etc, out of the engine. If possible, I'd like to fix it myself. I don't want to loose any more money on a mechanic diagnosing the car. What should I try? I have a spark/ignition tester, so I'll start there. Since it's getting more fuel than it needs, and if spark isn't the problem, a bad injector, or bad signal to an injector maybe? |
(Post 716489)
If possible, I'd like to fix it myself. I don't want to loose any more money on a mechanic diagnosing the car. What should I try? I have a spark/ignition tester, so I'll start there. Since it's getting more fuel than it needs, and if spark isn't the problem, a bad injector, or bad signal to an injector maybe? If it is a totally dead cylinder, you should be able to find it with a IR temp gun on that runner. Once you've found the cylinder, there are only a few components involved. If it's a pair of cylinders, it could be a coil pack. If it's all over the place, it could be a ICM, the PCM, or a bad sensor. The hard part is that the diagnostic path varies greatly depending what each step tells you. Trying to map out every possibility is too tough to do here, hence why I suggested looking at the scan data first to at least get you headed in the right direction. |
