-   -   overheating (https://montecarloforum.com/forum/monte-carlo-repair-help-8/overheating-26752/)
jimp00 Mar 14, 2011 07:38 PM
overheating
Is this a common problem with mc,my new problem is the gauge goes up to about half and then goes back down.I put in a new thermostat,water pump,drained the system twice,tried purging it no antifreeze comes out.When should the fans go on,checking them out today.Thanks again for all the help
ChibiBlackSheep Mar 14, 2011 07:44 PM
Halfway on the gauge is the stock reading for the 195° thermostat
Fans kick on at 212°
jimp00 Mar 14, 2011 07:49 PM
Thanks for that info is hot when I take off the radiator cap off also why would the gauge be going up and down
ChibiBlackSheep Mar 14, 2011 08:08 PM
Stop and go driving? Or all open air??
jimp00 Mar 14, 2011 08:14 PM
Went for a drive 250 miles would that tell me
ChibiBlackSheep Mar 14, 2011 08:39 PM
Just was wondering if the temperature rose while stopped in traffic, then went down when moving because that would be 100% normal.
jimp00 Mar 14, 2011 09:35 PM
seems to do that in both situations,any reason why it wouldnt purge all the air out of the system
ChibiBlackSheep Mar 15, 2011 07:31 AM
When you replaced the thermostat, you bled the air out completely correct?
You just open the thermostat bleed screw and wait for the car to get to normal operating temperature where the thermostat would open. Could take 10-15 minutes
jimp00 Mar 15, 2011 02:09 PM
Did that to nothing coming out,is it suppose to put out a little anti freeze when the air is all out.
ChibiBlackSheep Mar 15, 2011 02:28 PM
Yes, once the antifreeze starts to come out is when you stop and tighten the bleeder back up.
