ok i need some help with temp sensor
Old Apr 27, 2011 | 03:04 AM
CashMoney's Avatar
Default ok i need some help with temp sensor
about 4 days ago while driving my temp gauge dropped to 0 so i changed the temp sensor. it worked great not 2 days later driving home from work and the gauge just dropped to 0 again. is it possible that this sensor has gone bad in just 2 days ? it is covered under warranty from auto zone so i have no problem changing it again if neccessary but i am kind of curious if there could be a bigger or different issue here that i am over looking.
01 monte carlo LS
3.4 L engine
68,000 miles on engine
Old Apr 27, 2011 | 09:12 AM
Wilco's Avatar
I would replace the sensor but check the sensor connector for loose wires. I've bought brand spanking new sensors that died within days of being installed so it isn't a rare occurrence.
Old Apr 27, 2011 | 11:40 AM
Furder2010's Avatar
I also replaced the thermostat when my temp gauge went out...it's like $8 from o'reilly's, you might just replace it too? Also, you may have to clear the check engine code if you have one and it didn't go off?
Old Apr 27, 2011 | 05:47 PM
CashMoney's Avatar
thank you guys. i just put the thermostat in a couple days ago when i changed the sensor. went out and just started wiggling the wire around and the gauge started to work so now it looks like my next project is to trace the wire for the bad connection.. somehow this does not sound fun but at least going in the right direction.. thank you
Old Apr 26, 2012 | 08:30 AM
James O'Conor's Avatar
Don't rule out the stepper motors in the dashboard. They are a bad part and have since been upgraded.
farmerjg
Feb 7, 2013 10:05 PM
nebstewart07
Jun 19, 2009 08:38 AM
smolek37k
Dec 1, 2007 07:08 PM
ajsbengals
Feb 8, 2007 03:08 PM
mickey
Aug 23, 2006 05:31 PM
