Info: noise after new front end parts install
Hey peeps! well I installed new inner and outer tie rods, and control arms/ball joints this past weekend, drove to auto store to return inner tie rod tool...btw, what a piece of **** this tool is! anyway, drove ok except for the cocked steering wheel needing alignment. couldn't get alignment Monday, too bust so drove it to work, 8 miles, on way home I get this high pitched squeal almost like brake pads but gets worse when turning? I replaced my front hubs about 5 years ago, new sway bar with poly links, new c/v half shafts about a month ago! WTF!! I was hoping for a brand new riding car with a new front end!! could my wheel hubs be bad again due to bad c/v axles and tie rods? Im getting this high pitched , metal on metal sound while driving and its worse when turning hard right and left into driveway or parking space? I am getting the alignment done in the morning but my stepson says they cannot do it if the bearings are bad? HELP! at my wits end with this car!! I also have a squeaking...ernt ernt sound when turning right hard into driveway etc. that I thought would go away with these new front end parts!! any help is appreciated greatly!!... Clay
My first two thought are either a bent brake dust shield or the wheel bearing is getting bad, maybe it started getting bad when you changed the cv shaft and re-torqued the wheel bearing too 118 ft lbs (1995-2007) too loose or over tightened are both bad. As #3 driver Dale stated jack up the car under the lower control arms to keep weight on suspension and try shaking tire and check for looseness. Can also run while it's in the air and check. Be aware that the traction or ABS light might come on, nothing exciting. Good luck
Good call Jeffs!! bent brake dust shields on both sides ! I squealed into Sun Tire Tuesday morning for the front end alignment and they heard me turn in squealing!! LOL, 5 minutes on lift with a long screwdriver and it was fixed then onto alignment rack, 30 minutes later I drove off with no noise and a super handling monte with a new front end!! thanks for the replies guys! appreciate it !!, Claydoh
6th Gen ('00-'05): Front end vibration when turning left
gtr25
03-10-2016 10:28 PM
6th Gen ('00-'05): Ball joint or tie rod end?
John1980
04-30-2015 08:01 AM
