No horn
Bought my Monte and the horn don't work. I've taken a part the steering wheel and it has one part missing its the part probably makes the horn ground. all I know is the part cost $25.00 . This I a 84 Monte. Did these cars have a horn relay? the horns themselves work.but I don't know much about what I have to do to get the thing working from inside the horn button. any ideas? the fuse block has been really hacked. I found out when the horn fuse is but there is another wire in there with no fuse. Hacked up remember, can I run a wire from the horns to the inside of the car and connect it to a toggle switch, and use that? if I did that where would be my power source? Let me know Dave
Originally Posted by djpink1947
(Post 714853)
I had an 85 Monte years ago in 1986 I got it had about 500 miles on it when I bought it. But I can't remember when all that stuff was. Now you need a donor car to fix all the little things. https://www.google.com/search?source...31.CuL8rVCXa1s |
