NAPA crows feet
I was looking all over for some boxed or flare nut crows feet or offsetsocketsto assist with the changing of my coolant temp sensor(9/16") since I didn't want to remove the front half of the exhaust system. The Cornwell tool guy had ONE for $20 and it would be at least a week out. I called all the local tool sources to no avail, not even a special order. I called NAPA and they had a lifetime warrantyset for $17 and change...in stock. On top of that, I get a AAA discount. These crows feet are nicely made and thick...they are flare nut style, so it is perfect for changing the coolant temp sensor on the 3.4. There is no comparison between these and the generic bargain crows feet you get at flea markets and the sort.
Just thought I would post up, since it saves over the $200 estimate in labor to change the part. |
