Monte Stalls when starting
For the past 2 weeks my monte will randonly stall out when i start it, sometimes it wont start again unless i pump the gas like its got a carb, anyone know the problem?
Sounds like you have a fuel issue. Either the pump or the filter is choking fuel from the engine?
Maybe even a clogged injector can do this? But I'm not too sure. |
