monte problem
ok so i have been having problems with my dearest monte...first i had a 4 inch spectre filter that one, clogged up the hot wire maf sensor and ruined that and two, sucks in WAY too much air and made the pcm command rich but couldnt compensate enough so it was lean still LTFT is at -12% but its heating up and having lean symptoms. When its on the road and you open it up it goes to 4 grand and doesnt go anywhere until you let off the throttle i replaced the maf and put the stock air box back in. now it stumbles and occasionally dies at idle under load or at a stop. Im almost possitive its good now but it just needs to reset the fuel map that is built into adaptive strategies anyone know how to do that? i have the battery unplugged so hopefully that will work but i know computers hold info well even without power. a thought also crossed my mind about o2 or cat? tell me whatcha think
if its running lean that shouldn't hurt the cat too bad but rich will destroy it fast. i'd be concerned about an intake leak on the UIP. it should never matter how big a filter you put on because the throttle body will only allow so much air into the intake. the MAF sensor has been replaced correct? to find a vacuum leak run the engine at idle and spray throttle cleaner around the intake gaskets vacuum lines and anywhere after the MAF. do this when the engine is cold startup because you don't want a fire to start off the manifolds when its hot.
how many miles/kilometers on the car because the cat is a very likely cause of what your experiencing. it just doesn't explain lean condition you could have 2 issues going at the same time.
117k i am almost positive there isnt a vacuum leak bcuz it would have to be large for this and then you would also notice it in your brakes and other vacuum assisted items but right now after a start from cold if i dont give it gas it will die out and when it finally stays up it sits above 2000 its warm in under 5 minutes which would make sense with a clogged exhaust and theres a rattle in the pipe as if the cat pieces broke off and are in the pipe...hand at exhaust its just warmth no cylinder pumps
Also, having a -12 fuel trim means that the PCM is pulling fuel, not adding it. If the MAF was reading so much more air due to the new filter, it would be adding fuel by means of a positive fuel trim, not taking it away. Negative fuel trims mean its seeing the engine is running too rich- and having the fuel trims that far off a near stock engine makes me think that there is a mechanical problem somewhere (O2 sensor not giving the correct info, MAF sensor giving incorrect info, fuel injector leaking fuel when closed, etc).
well the cat is off now and same ****...im thinking fuel filter now
it sounds like your car is in limp mode due to some thing wrong some where down on the line. the best thing is have some one that has a gm thech tool scaner and have it checked out. you can replace alot of parts with out having a scan done. bumpin is right about the timing and every thing about the 3800 motor. i would just check the computer out is should pop up with some thing with one or more sensors not working right.
