MC Popping Noise
My 2004 MC SS Supercharged has developed a "popping" noise. The axel's have been replaced.
The popping noise happens when putting the car in reverse on cold start. It also happens when slamming the gas at a red light .. We jacked it up, spun the tires .. The popping noise is happening no matter which tire is spinning. Seems to be a lot of slack. Transmission going out? |
Hi `Brad,
Maybe it's a bad U-Joint ? I hope one of our expert MCF Mechanic's see's your thread & post their thoughts ? Good Luck :thumbsup: 2004 Chevrolet Monte Carlo Ss - Driveshaft, U-Joint and CV ... www.discountautoparts.com/ShopByVehicle.epc?...2004@@2004...16@... Availability: In Stock; Notes: Front ; Right ; New ; 1 Per Veh;CV Joint Half Shaft; Years:2004-2005; Vehicle: 2004 CHEVROLET MONTE CARLO SS V6-231ci .
#01-02-32-001O: Clunk Felt/Noise Heard From Stering Column, Steering Gear and/or Front of Vehicle During Turnign Maneuver and/or Steering Wheel Rotation (Replace Intermediate Shaft As Directed) - (Mar 27, 2008) Models:2001-2004 Buick Regal 2005-2007 Buick Allure (Canada Only), LaCrosse 2000-2008 Chevrolet Impala 2000-2007 Chevrolet Monte Carlo 1998-2002 Oldsmobile Intrigue 2004-2007 Pontiac Grand Prix |
Was it popping prior to having the axles replaced?
Off the top of my head I'd say loose bolts or worn carrier bearings. |
It started making the noise after axles were replaced.. Carrier barrens? Motor mounts?
