-   -   this may help with the 3.5l spark plugs (https://montecarloforum.com/forum/monte-carlo-repair-help-8/may-help-3-5l-spark-plugs-14993/)
monte07 Jul 24, 2009 09:38 PM
Found out with a little help with some people here.
To get to the back three plugs on the 3.5l motor is to remove the coil pack and the bracket. also the altenator because the altinator impeads as in blocks the #1 plug wire and plug. also you may need to pull or raise the motor may be a inch with a jack and a block of wood. or have a freind with you to pull the motor to the front with a dead puller and a really big tree. may have picks on the install if my didgital and computer will like each outher. outher than that the front three were a brease wish the outher three were that easy.
MAMONTE Jul 24, 2009 10:54 PM
Yea, if you could post a few pics, that would be awesome....I paid the dealer to change them at 50,000 miles...it was like $250 for just the plugs and install....Although out plugs are expensive since just the OEM plug is an Iridium plug...I think parts alone were $70bucks.
moonlitmagik Jul 25, 2009 02:48 AM
And this is why we don't take our cars to the dealers for anything....
Man... I really need to become familiar with my dad's toolbox. Or I have a feeling I'm going to be spending a LOT of money getting this car regular maintenance...
sonin66 Jul 25, 2009 07:02 AM
you paying that much is crazy, esp at 50,000 miles.
monte07 Jul 25, 2009 08:53 AM
the most expencive thing on the plug and wires are the wires. it seemed that no one has them because when you remove the boot from the spark plugs the stock wires has a habit on coming apart. when pulling from the boot all in all the e3 plugs causted me only about may be 35 a little cheaper than the iridiom plugs from ngk. but the e3 plugs are standered iridium any way. plus they have more of a contact surface for the spark. have them in two vehicles a mustang and a silverado z71 also my dads mazda 6 v6 , pertty much sold on them. because i noticed out of the three got a increase in gas milege and better responce just out of just a tune up out of the difference in plugs.
monte07 Jul 25, 2009 09:13 AM
the picks on what i did
3 Attachment(s)
found out that i didnt need to remove the altinator all the way off foud out the hard way just wanted to let every one know other models may may not need to do that step as in removing/ lossting the alt
drewskie043 Jul 26, 2009 10:05 AM
thanks for the pics and info monte07. i will skin up a few knuckles before i shell out a couple hundred bucks to the dealer for spark plugs any day;)
monte07 Jul 26, 2009 04:20 PM
it will be only the left thumb knuckle that will bee skined a little reachin for #1 spark plug. outher than that look about 25 minuted for diss and assembuly
MAMONTE Jan 22, 2010 10:45 AM
I'll be doing this myself in a month or so. Good Info, thanks Monte07!
monte07 Jan 23, 2010 04:32 PM
what i looked up with e3 they are the same manufacturer of acdelco and ngk they are the same type of plug with different labels and tips. i perfer the e3 do to contact.
