-   -   6th Gen ('00-'05): Low Tire Pressure Message does not go away (https://montecarloforum.com/forum/monte-carlo-repair-help-8/low-tire-pressure-message-does-not-go-away-49778/)
MonteCarloSS02 Jul 27, 2014 09:14 PM
In the "message center" on the dash of the car, it constantly says 'Low Tire Pressure' even after i have "fixed" the problem. Any help? My car is a silver 2002 Monte Carlo SS.
Thanks.
Aaron0313 Jul 27, 2014 09:27 PM
with the vehicle running pull the headlight knob out one position/click, push it in, pull it out, push it in, pull it out and push it back in all within 5 seconds. It should reset that.
ZIPPY02 Jul 28, 2014 12:30 AM
If you still have your factory radio that is what you will use to re-set your message center notices. Look in your owners manual or go on line and read about how to re-set your low tire pressure message.
And Welcome to the Forum!! See this is your first post, nice to see another 2002 Monte show up...:thumbsup:
MonteCarloSS02 Jul 28, 2014 08:22 PM
Thanks for the help guys, got it fixed!
TPStatic Aug 6, 2014 04:10 PM
Yes. Thanks Large.
It was last bubble after:
New tires
Reformatted CPU
HV intake kit from AS
Down pipe from ZZ
KN Air filter
Throttle body mod
33 mm front sway bar
Slotted and drilled disks
New carpet
Kenwood amp and radio with Focal speakers.
Intake mod
Steering pump
Knock sensors
Transmission rebuild
Piece of mind. Priceless
michelob Aug 28, 2014 10:23 PM
Had the same issue this technique works like a charm to reset it. Thanks man.:thumbsup:
panpan Aug 29, 2014 08:46 AM
This is a much better way than with the radio !
Where do you find these tricks ? Is there a list somewhere ?
A similar technique for the oil change message would be helpful too.
