low tire pressure
Old May 19, 2005 | 07:41 PM
chevy_jj's Avatar
Default RE: low tire pressure
yes that is correct, it would set the light if you had different size tires as well. it uses your abs sensors to tell if one tire is low, or freewheeling at a differen rpm than any tire that is its direct opposit in rpm.
Old May 20, 2005 | 12:28 AM
warpath's Avatar
ORIGINAL: chevy_jj
i just came back from my first trip in my new 05 monte, i went from owensboro,ky to daytona
beach,fl, about 25 miles into fl,my low tire pressure light came on, i pulled off to the side of the road,tires looked normal, but i gaged them anyway, all 4 tires had exactly 35lb's psi . to me
there was no reason for that light to come on, i will be due for my first oil change in about 300 miles now after the trip i will request this system to be checked for a faulty sensor.
Old May 20, 2005 | 10:01 AM
montejass's Avatar
Welcome back David....
Other than that did your trip go ok?
I am headed off to LA this morning; unfortunately it will not be in my Monte...
TVW
Old Aug 16, 2009 | 04:26 PM
nolan28's Avatar
how do you clear the message center with an aftermarket stereo???
Old Aug 16, 2009 | 04:32 PM
2000_BLACK_SS's Avatar
put your key into the ignition Turn key to the on position but do not start the car.
Then pull the headlight switch out one Click puch back in one click. pull out one click, push in. pull out one click, push in. (total of 3 times) and the light should go away.
It will make a chime sound if you do it right.
has worked on mine every winter and spring when i swap out the winter rims with the summer rims.
Old Aug 17, 2011 | 08:52 PM
68 chevy's Avatar
Originally Posted by montejass
As usual Chevy_jj, I would quote you on this one....
I've read the same as you have outlined. From what I have learned of the LTPS I don't think there is a sensor per say in the tire but I think it monitors rotation speeds of the tires. Chevy, do you know of the mechanics of the low tire pressure feature?
TVW
it works by the abs sensors it is called a indirect system. when 1 tire is low it turns at afaster speed.after a x amount of time the ecm will turn on the light.to reset the light key on radio off. push and hold displ button till settings is on push the seek-pscan button tire moniter comes on push the#1 button it will say reset. push the displ button it will say done and light will go out. rick.
Old Aug 18, 2011 | 08:10 AM
No need to answer a question from over 5 years ago!
Old Aug 25, 2011 | 12:55 PM
xambdriver's Avatar
I recently put new struts on the back of my 2000 Monte Carlo SS their was aprroximately a 1-1/2 in increase in height within 10 minutes of driving the low tire press warning came on. All tires were within 1-2 #s of each other .I have reset the message and have not had the message reappear yet.
Old Mar 14, 2012 | 01:27 PM
Antdeez's Avatar
if i have a after market radio how am i supposed to reset the message center on my 2001 monte carlo SS?
Old Mar 14, 2012 | 02:46 PM
03SSLE's Avatar
For the low tire pressure monitor, turn the key to the ON position (don't start engine) then turn your parking lights on/off 3 times in a row.
