Low beams not functioning
Good afternoon all. My Low beams have stopped functioning. DRL's, hi beams, dimmer switch, parking lights, fogs all working. I installed HID's a few months back and they have worked great up until yesterday. Any help would be appreciated. Thanks,
Hey damien, first step is to install a standard bulb and see if they work. Let me know how that goes and I can give you the next trouble shooting steps
Originally Posted by dbaldwin
(Post 613238)
How about the fuse for low beams under the hood. Mine blew out a week ago and I had the same problem.
Originally Posted by Habbibie
(Post 613256)
Ok, so if original bulb doesn't work look for the headlight relay. It should be in the main fuse block under the hood.
It's a 50A square fuse that you can see from the top if it's blown or not. When I'm by the car ill snap a pic of it
Have you checked the fuses?
Underhood Upper fuse panel: DRL/EXIT LTS EXIT LTS If you used a harness to tap power directly from the battery there is most likely an inline fuse in it also. |
Yo fuse blown homie, my hids blew like 3 of mine lol
(Post 613490)
| All times are GMT -5. The time now is 10:33 AM. |
