keyless entry receiver
Can anyone tell me where the actual receiver for the keyless entry/remote start is located in my 2006 Monte Carlo LT? Sometimes I cannot get the doors unlocked from the passanger side rear unless I am within about 4 feet of the car. Anything over 5 feet, anywhere around the car, and the remotes do nothing, both remotes. I replaced both batteries and reprogrammed the remotes through the info buttons on the dash, and the dealer says they work fine. I had a 2006 Impala loaner, and I could lock the doors and start the vehicle from my second floor motel room, but I cannot do this at all with my Monte. I have to be pretty close to the car for these functions to work. Any help would be great!
RE: keyless entry receiver
What is with the 06's and remote probs??? Hasn't the range problem been brought up a few times here?
Just would like to know where the friggin reciever is located.
Keyless entry remote antenna location
While this issue comes up several times, I have not seen a good answer here on this site...so I went to Remote Keyless Entry Antenna Change - GM Techlink
and got my ans...This is why I don't like this site and don't use it, because most of the answers are not serious and the reponders are just putting done someone for asking certain questions. |
On the 2000 though 2005 Monte, the receiver is mounted under the upper dashboard cover just to the right of the driver. It's probably the same on the 2006.
| All times are GMT -5. The time now is 05:01 AM. |
