jerry58
have a 2000 ss not running....problem is with key on i have nothing but engine light on no dash lights,no headlights,no radio,no dome light nothing, engine will crank but no start? anyone got any ideas?give a starting point,have put in new ignition switch.
:( no crank/no nothing have 12 volts on battery,and fuse boxes under hood .relays are good any one? |
>Good Luck
Hi `Jerry & Welcome to the Monte Carlo Forum.
Click the below link & explore the topic's that may help you. FWD Tech Guides '95-'07 - Monte Carlo Forum - Monte Carlo Enthusiast Forums :rolleyes: Also, keep checking your thread to see what our expert tech member's post to help... Good Luck |
Welcome to the forum!! :)
thanks !
make sure you check ALL the fuses in all the boxes. You also should have one inside each door on each end of the dash as well as the one under the hood.
