Opinion Needed: Intermittent vibration with clunking...
I have a 2004 Monte Carlo 3.8ss non-supercharged. I am experiencing a vibration with a clunking sound coming from what seems to be the front driver side. Its off & on / rough or smooth at various speeds. I've change the hub assembly & the cv axle. The issue still exists. While making those repairs I inspected all visible rubber boots & bushings. The only thing that showed any damage was the boot on the outer tie rod end. There is a split. I stuck my finger inside & felt some grease but no grit or debris from what I could tell. When I turn the wheel while driving or stationary it is smooth with no clicks or clunks or any noise. I do know that because of the split in the rubber boot of the (outside) tie rod end, the tie rod end should be replaced. But, could that be the cause of the intermittent vibration & clunking while driving, or could it be something else?
I truly do appreciate all of your help, tips, advice & suggestions.
- Ken Flucas
- Ken Flucas
What about your Brakes and rotors,?
- Ken Flucas
- Ken Flucas
Lug nuts should be at 100ft lbs on the torque wrench.
ThomasB81677
06-17-2019 08:26 AM
6th Gen ('00-'05): Front end vibration when turning left
gtr25
03-10-2016 10:28 PM
6th Gen ('00-'05): Changing Tie Rod Ends.. Is it hard?
iMSeRiOuS
03-24-2013 09:32 PM
