How to replace PCM in 2002 MOnte Carlo
Found out my unit went bad and its the reason my engine fans no longer come on when the engine gets hot. I see the part for sale for around 75 bucks but i dont see how to install the thing anywhere.
1. Where is it located? Dealership said in the airbox on drivers side and some sites say ECU is at left front of engine compartment.
2. Is a PCM, ECM, and ECU the same thing?
3. How hard is this thing to install?
take your left side support brace off (13mm socket and a ratchet) remove the 8mm bolts holding the air box halves together and finish taking the air box apart the computer inside is the PCM, or ECM. a dealer will have to reprogram the computer and it is NOT DRIVABLE after its been changed, don't even re-connect the battery. so its better to just let them change it unless you want to purchase a performance programmed PCM but i wouldn't recommend that. just buy a programmer if you want to tune it.
PCM= Powertrain Control Module
ECM= Engine Control Module
That would be pretty shady to do if the pcm does actually have an electrical problem inside of it. I'd imagine they'd get it, reflash it- and send it out to another customer who would then get the problem. I don't think they do any testing of the pcm's to check for stuff like this before they flash them and send them out (maybe the pcm does its own check when they flash it?)
Either way, if they found out- you'd definitely lose your core money. The core charge for a tuned pcm kindof implies that you are sending in a working pcm, its not like a core charge at an auto parts store for a worn out alternator or something.
Thanks. Ive found someone who will program the computer with my VIN. The dealership is not an option as they want 800 bucks for a new one installed.
