how to get codes without code finder?
my local NAPA said there is a way to get a code from the car, with the blinking engine light, without a code finder...he said he doesn't remember how,but that you do something with your key and the engine light will blink...i've always though you need the OBD machine for that...is he right?...if so, anyone know how?...thanks....
how to get codes without code finder? - Monte Carlo Forum - Monte ...
montecarloforum.com/...monte-carlos.../how-get-codes-without-code...
2 hours ago – my local NAPA said there is a way to get a code from the car, with the blinking engine light, without a code finder...he said he doesn't remember how,b. ...You may have to register before you can post: click the register link ...
6th Generation: how to get more power without ... - 10 posts - Aug 27, 2012
RockAuto Discount Code - Expires 10/06/2012 - Monte ... - 5 posts - Jul 6, 2012
read check engine light codes without scanner - Monte ... - 6 posts - Dec 19, 2009
More results from montecarloforum.com »
Click above links to see if they help..
Your Thread question is now on a Google Search
Good Luck
Good Luck
what sort of monte do you have and what year .As fgar as I know there is no way to do that with the key and engine light you need a obd to check engine codes .You can go to cap or advance auto and they will put the obd reader on your car . The guy at napa does not know what he is talking about just by him say"he doesn't remember how" is a dead giveaway he does not know
good luck
good luck
The blinking engine light for retrieving codes was used on GM vehicles with the OBD I through '95. But, some vehicles do not comply and require a scanner. This web site should help you to understand how to get and understand the codes:
http://www.troublecodes.net/GM/
Thanks you again Seattle `Mike for posting the above link to help a member
...I was searching for that link, but could not find it...MCF = Member's Helping Member's....
thanks so much for this...this is perfect...i'll update with my findings...thanks again....
i put in the jumper wire, turned the ignition to on, but not starting the engine...the check engine light blinked once, then stayed on...not sure what that means according to the instructions...i'm lost again...
Is it a single flash or a series of flashes? 1 long and 2 short flashes would be a '12' meaning no codes have been stored. It may also be that your particular vehicle requires a scanner to retreive the codes.
