horn on '06-'07
Does anyone know anything about the horn on the '06-'07 Montes? Are there one or two horns, and where are they located? I tried looking under that plastic cover between the grille and radiator, but I couldn't see them.
My horn doesn't sound quite the same as it did when I bought the car. It doesn't sound as strong. I'm thinking if there are two, maybe one of them isn't working. |
Hm... Sorry I can't help, I hope you find your answer. Do you still have your warranty? If so take it to the stealer.
know mine has 2 horns. They are between the grill and rad. But mine is a 5th Gen so it may be different.
(Post 165614)
Two horns, behind/under the passenger side headlight. They should both be attached to a bracket.
Thanks, Garrett. I'll check that out when I get a chance.
Yep, I remembered seeing them somewhere so I pulled out my Haynes Manual and that's what it said. Let us know if you find out anything
You are right.. Two horns behind the passenger side light.
Originally Posted by God_Bot
(Post 165826)
Originally Posted by slinkeey
(Post 166150)
Taking out the right side headlight is also a good way to see how much fluid you've got in your windshield washer reservoir, or to change the bulb in your fog light if you need to. |
| All times are GMT -5. The time now is 03:19 AM. |
