HighBeam Light (2001 Monte Carlo LS)
The HighBeam Out light came on in my wifes's car the other day so I replaced the bulbs. Now, with the daytime lamps running the highbeams wont come on when you pull back on the turn signal stalk but only will come on when you pull the knob back for the Lowbeam/Parking lamps and the HighBeam Out light still comes on occasionally.
Any input would be greatly appreciated. Thanks Jason |
Hi Jason & Welcome to the Monte Carlo Family..
Sorry to read about your problem...Where did you get your bulb (What type/manufacturer bulb #)...Did you notice any corrosion ? Did you have any problems with your light switch before your light problem ? How many miles on your 01 LS (How much use) Please check back on your thread problem to see `if any of our expert member's can help...Good Luck EnJoy the MCF p.s. Check out our search engine for same or smiliar problems on headlight issues.... |
Thanks for the welcome Space :)
I got the bulbs from Walmart, Sylvania Xtravision 9005. There was no corrosion but I did go ahead and clean them anyway. We never had any problems previously with the light till the other day when the HIGHBEAM OUT light came on. The car has 112,000 miles on it. |
Hi `Jason,
Check the below link to explore the problems of a 2001 Chevy Impala with similar headlight problems.. Then keep checking your thread to see what our expert member's in this area post to help you...Good Luck there were several possibilities: broken wire, loose ground connection at left side of dash, blown fuse,faulty headlamp relay, faulty dimmer switch and faulty body control computer. The dimmer switch however was the one point were most things could be checked. :rolleyes: Click above link |
You know the high beams are the daytime running lights right?
