-   -   High & Low Beams always on..... (https://montecarloforum.com/forum/monte-carlo-repair-help-8/high-low-beams-always-13062/)
Zubius Apr 13, 2009 08:03 PM
After going through 40 pages I could not find any info, Sorry if this is a repeated question.
2003 SS. My "highbeam out" message came up, but when I check they are on. I pulled all the bulbs and they are good. While the car is running the highs & lows are on but the lows are very dim. When I pull the switch all go a bit brighter but not much. Does this sound like the multi switch or a more serious electrical problem?
Thanks!!
sonin66 Apr 15, 2009 07:29 AM
try resetting the car by taking off the negative line to the battery
owens91 Jun 4, 2013 07:17 PM
ive been looking all day for a solution to this, i finally found someone that is having the same problem as me, i hope that someone will see this and also chime in or by any chance you came up with a solution. (even though this is a really old thread)
