HID Headlights
Does anyone know where to get hid headlights for a 2004 monte? What brand is good? I found these http://www.amazon.com/JLM-Conversion...8510977&sr=8-3 but I don't know what brands are good.
zzperformance.com has a conversion set.
ebay has the most selections for cheaper. i believe your bulb type is a 9006 so you could search 9006 hid or something like that
Originally Posted by csmith045
(Post 119657)
Does anyone know where to get hid headlights for a 2004 monte? What brand is good? but I don't know what brands are good.
:rolleyes: HI Member: CSSmith, I think projectors are a awesome `Mod 4 your Monte. Several Members have them & luv them. Give some time 4 them 2 C your post, and I am sure they will advise.. Below are a few links to check `out until you obtain the infor U desire. Good Luck Below is your Homework assignment :) Chevrolet Monte Carlo Headlights and Projector Headlights <LI about="r12">Add a set of Projector Headlights or Replacement Headlights to your Chevrolet Monte ... Headlights Fit 2000 2001 2002 2003 2004 2005 Chevrolet Monte Carlo ... www.slickcar.com/accessories/Chevrolet_MonteCarl... - 157k - Similar pages http://www.slickcar.com/accessories/Chevrolet_MonteCarlo_projector_light_conversion.as p Projector Headlights - Chevrolet/GMC LightsHeadlights Fit 2000 2001 2002 2003 2004 2005 Chevrolet Monte Carlo ... Projector Headlights fit 2003 2004 2005 2006 Chevrolet Silverado ... <LI about="r13">www.slickcar.com/projector-headlights.asp... - 171k - Similar pages http://www.slickcar.com/projector-headlights.asp?SubCategory3ID=138 2004 CHEVY CHEVROLET Monte Carlo super bright automotive lig... 2004 CHEVY CHEVROLET Monte Carlo automotive lighting - hid headlight on your finger tips, we offer PIAA automotive light bulbs - new led automotive light ... www.eautoworks.com/html/bulbSearch-2004-CHEVY~CH... - 19k - Similar pages |
I have got a set form ZZp and they worked perfect and then i ordered a set off of Ebay and had nothing but problems with them so i would say go with a real company not an ebay seller.
I've heard good things about the ZZP HIDs, also, altho I personally don't have a set.
the best makers of the hid kits are philips and mcculloch. they tend to have a 1-2 year warranty and are a bit more expensive
I have a question i have HIDs and sometimes when i turn the car on only 1 headlight comes on...and when i mess with the headlight knob keep turnin them off and on eventually theyll both turn on....i tried putting a relay in it helped but it still does it
that sounds like a ballast issue. it might not be getting enough electricity or something is screwey with it. mayby let your car run a minute before you switch them on. then if not i would definately start searching for another kit
my hids are phillips and theyve been good...i dont kno if a ballast is going bad or what i kinda figured its a electricity problem but i dont kno the fix...you think it has something to do with the day time running lights?
