Help: Finding 1976 Monte Carlo Factory Assembly Manual
Hi Everyone,
New to the forum. I have been looking for a 1976 Monte Carlo Factory Assembly Manual and cannot find one. The best option I can find is a 1972 Chevelle and El Camino Factory Assembly Manual (with the word Monte Carlo on the cover) as shown here . I am interested in how the front half of the car is assembled (suspension, front brakes, sway bar, etc) and not interested at the moment on the service or body. I am interested in torque specs, part numbers, diagrams for assembly, etc. Is it possible that the 1976 Monte Carlo can be assembled using an older factory assembly manual since I cannot seem to find one specifically for 1976? Can someone point me to the correct Factory Assembly Manual for a 1976 Monte Carlo? Thank you for your assistance! |
It's is possible to assemble using a 73-77 if your looking for torque spec's and assembly pictures. Not sure what copy's of manual's your looking but Chilton is probably is your best bet, not sure about Mitchel unless you can find a dealer shop and service manual. Good luck and hope to see some pic's of that 1976.
Hi Jeffs02rwddSS,
Thanks for the response. Would you happen to know the URL for an example of the 73-77 assembly manual that i could purchase? When i google for the 1976 Monte Carlo Factory Assembly manual, i cannot find an assembly manual"specifically" for 1976. I do see service and overhaul supplement manuals, as well as a automotive repair manual for 1976. But I am not sure which would be the correct manual for assembly instructions? I seem to be baffled on finding the correct manual for assembly :-) Again thanks for the assistance. |
Repair manual should have what your looking for and the service and the supplements should also contain same information .I did a quick google search and found OPGI has something also. https://www.opgi.com/monte-carlo/CH2...CABEgJn8vD_BwE but might be the one your referring too . I did a 1976 Monte Carlo repair manual search
Jeffs02rwddSS,
Thanks again for the quick reply. That is the one i will purchase then. |
