wheel studs
Old 12-20-2006, 10:25 PM
taki0187's Avatar
Default wheel studs
My son has a 1997 MC LS it had steel wheels he went and purchased Z34 aluminum chevy montewheels, my problem is when I went to mount the aluminum wheels on the car the lugs only catch the studthread by about 6 threads. I did some research and the Z34 and the LS with steel wheels take the same hub bearing from 1995 to 1999 and no mention about longer studs with aluminum wheels. Just wondering if anyone had a similar problem. Thanks in advance.
Old 12-21-2006, 02:02 PM
Default RE: wheel studs
There are special lug nuts for aluminum wheels...they havea longer .746" shank, and a stainless washer.I just bought a set for a customer yesterday. The onesI got were made by Mcgard. His lugs are M12x1.5 hope this helps.
Old 12-22-2006, 01:35 PM
taki0187's Avatar
Were the wheels you put on z34 aluminum chevy wheels and what year was the car and if you have a part number it would be great. Thanks
mhenderson
05-21-2013 03:01 PM
basicdumbass
06-07-2011 05:37 PM
nitehawkjcb
01-06-2010 01:46 AM
Martelli
06-25-2008 04:00 PM
Pjw350
03-20-2006 05:33 AM
Quick Reply: wheel studs
