Any recommendation? I need HD lights for my towing truck we have ram 5500 which we are using for Roadside Assistance Services, i need to install a hd lights any suggestion?
fried looking connector to low beam
https://cimg2.ibsrv.net/gimg/monteca...a9fc2d46b8.jpg
https://cimg3.ibsrv.net/gimg/monteca...59c341c1e3.jpg https://cimg4.ibsrv.net/gimg/monteca...4daf4e6c97.jpg For my 2000 SS , I had tried some Xenon Halogen Bulbs that were working for about 5 years but .... one stopped working and I just hit the top of the hood and it always seemed to come back on , I finally went to change the low beam bulb to find out that electrical connector looks fried . Is there a way to get a connector end part to replace the fried one ? I'm not sure if would be able to do it though . I'm not to good with electrical stuff . |
The local parts store should be able to get the connector for you. Easy 2 wire hook up so installation is easy. Good luck
https://cimg5.ibsrv.net/gimg/monteca...947f480d55.jpg
Thank you Jeff . How about this part ? It's ceramic so it hopefully burn (plus I will only use proper bulbs from now on) , Are Philips 9006 Vision Upgrade Headlight Bulbs any good ? Thanks again . |
Yes that appears to be what your looking for , just remember to use some butt connectors and tape or shrink wrap to protest the connection.
Thank you .
The connectors ended up working perfectly , If anyone ever needs to do this project this could have not been easier . Just took about 1/2 hour for both headlights . I had some junky bulbs in there which caused this problem in the first place .
The Phillips light bulbs were also very high quality ... Though I'm thinking I should have gotten some stronger ones since these connectors are ceramic and can handle it . I only got the ones that say 30% more vision, But these should last a long time. Thanks again Jeff for your input . You saved me $200 :) |
Glad you got it fixed and saved a bunch of money. Like everyone here , I try to help when I can.
Headlight adj screws
Originally Posted by Yellow_Monte
(Post 12353)
Okay thanks for all the good information. BUT, I really need to know which screw I turn? There should be two on each headlight if I'm right. One for left/right, one for up/down?
Spoiler
Originally Posted by trevermck
(Post 725577)
Spoiler
