| 97montelt |
Jul 22, 2007 12:05 PM |
hard starting
ok, been havin problems with my 97 monte. first off, it sat for 2 years with the batt. disconnected. when i finally got around to it, i did the manifold gasket replacement, and a new egr as well. put a new battery in, and it takes forever for it to finally start. almost to the point of killing the battery. when i do get it going, it idles fine but has a bad hesitation when i throttle it, until it warms up. now i know that the pcm loses its memory when the battery is disconnected, and has to relearn all the values again. but this happens everyday. oh, and once its running and warmed up. it will restart like normal. i`m starting to pull my hair out. any ideas what is causing this ??? Thanx
