Gen1 Hood latch stuck.
Old Feb 11, 2021 | 11:53 PM
CARLO LS's Avatar
Default Gen1 Hood latch stuck.
I am wanting to know if anyone out there has had an issue with their first GEN hood latch not opening. I have tried to push down and pull on the lever. I cannot get this hood to release any ideas would be much appreciated. I might have to get the die grinder out and cut latch.
Old Feb 18, 2021 | 11:33 PM
mickey's Avatar
hope you have not cut it yet.
if you look behind the grill there is a long bar that comes off the latch assy. and goes to the handle you pull on to open your hood. double check it is actually moving and pulling correctly on the latch. the one i had you had to pull on the bar because the holes get wore out and cause it not to pull straight so it don't open. also you if you can find it the chevell is the same style and they are normally easier to find the the monte carlos.
CARLO LS
Feb 11, 2021 11:49 PM
74montes
Feb 3, 2019 02:39 PM
ThomasB81677
Jan 12, 2018 07:43 AM
Austinho_4
May 25, 2014 11:21 AM
Mr Grizzly Mint
Mar 17, 2012 11:02 PM
