skylark65 |
01-03-2010 10:36 AM |
it could be your sending unit has a bad ground due to rust / normal wear, but more than likely its the sending unit itself, which lives in the fuel tank. its a pretty expencive part, personally i fill the car depending on the tripometer, IDK how far you would wanna go with the 3.8 but my '97 LS with its 3.1 i usuallly go around 200 miles before i fill it up, its got a 16 gallon tank and will usually take 10-12 gallons at around 200 miles. due to its differant size, the 3.8 is gonna get differant milage, so you probibly dont wanna follow my numbers, lol.
good luck getting everything sorted out :)
