Fuel lines
I own an 02' 3.4L and I was wondering if the fuel lines for a 3.8L of the same year would work? I can't seem to find cut lines anywhere except a spot on ebay. I also can't seem to get my car to start after replacing the lines myself the first time, I know i might have to clean out the tank, but the fuel pump sounds only a little backed up. Thank you for any suggestions in advanced
So you replaced them yourself once, but think it needs replaced again and think the cause of your fueling issue could be the lines you replaced?
Did you kink one by accident doing a bend? |
(Post 725871)
Do you have a local junkyard? Should be able to find any W Body car with the same engine to use for quick reference.
Were they also the exact same size? Usually the return line is a step smaller on many cars. |
