Fuel Leak - Parts Problem
Has anyone run into the quick connectors on the fuel rail leaking? If so, where did you locate the O rings? Every part we tried came back for the Injectors and not the rings inside the quick connectors. One is 3/8ths and the other is 5/16ths, Rings fit over the line from the fuel rail but would not fit properly inside the disconnect fitting. Any help would be appreciated. Thanks!!!
I got some at auto zone. its an s o b to get the inner one changed out... much easier with an o ring pick a plastic dental pick, or you can buy the replacement qwick connect ends and just swap out the o rings
