Hey guys, so I installed the fuel pump assembly. took me about 1hr20mins. Here is a couple things to watch out for with aftermarket pumps, hope this helps someone else.
Expect to cut your wiring harness, and wire the new one in thats included. You will need to remove the other harness housing from the old pump and snap it into place onto the new one. With the new harness, it was designed wider, and there are 2 metal poles on the metal locking ring (assuming this is in case something heavy in the trunk crushes down, and smashes the harness). I had to spin that around from the 10 oclock to the 7 oclock position to relock the new pump in. Those are the not-so-straight-forward things I noticed and wanted to share. btw I have 1/4 tank of gas :p |
