-   -   fogs and headlights (https://montecarloforum.com/forum/monte-carlo-repair-help-8/fogs-headlights-52532/)
avendo Mar 24, 2015 07:25 PM
fogs and headlights
can you get fogs to stay on with headlights without pushing button?
avendo Apr 1, 2015 11:17 AM
no answer on this i guess...
JC Colon Apr 1, 2015 11:23 AM
You can Jerry Rig them so they come on when the car is turned on. But that's a good deal of under the dash work. If you have the Haynes or Chilton manual for the car you can see how it's wired. Then figure how to wire it the way you want! But in order to do it right you Need the wiring diagram!!!!
ohara Apr 1, 2015 01:52 PM
You may also be able to run a "hot" wire from the daytime running lights to the fog lights, but not certain if this would effect the lighting system in anyway, but it's probably how I would do it, although they may turn off when the daytime lights turn off
avendo May 1, 2015 12:08 PM
power to key to fogs,they will be on till they burn out,replace repeat.
