-   -   6th Gen ('00-'05): FM not working on radio (https://montecarloforum.com/forum/monte-carlo-repair-help-8/fm-not-working-radio-64328/)
spamdaddy Aug 22, 2025 01:23 PM
All of a sudden, the FM on my radio stopped working. The AM and SXM work fine. Anyone had this happen? How was it fixed?
Thanks
The_Maniac Aug 29, 2025 11:24 AM
So SXM uses it's own antenna. The FM/AM radio uses antenna lines that are also part of the rear defroster. There is a module hidden behind one of the rear interior panels that is connected to the process. I wonder if there is a problem with the connection to the rear glass or that module.
spamdaddy Sep 2, 2025 10:38 AM
Thanks for info. Any idea which panel?
The_Maniac Sep 4, 2025 08:13 PM
If my memory serves, it is on the passenger side, rear upper panel. I think you need to remove the clothing hook and it gently pops out.
spamdaddy Sep 5, 2025 12:41 PM
Thanks. I’ll check it out. Can’t be without my tunes.
