7th Gen ('06-'07): Error code P304 and P0011
Old Apr 10, 2018 | 04:41 PM
Ben10's Avatar
Default Error code P304 and P0011
I have a 2006 3.9L V6 Monte Carlo Lt. A few Days ago on my way home my check engine light came on and a few miles later it died at a stoplight. I got the car to start and it died at 3 more stoplights before i got home. I used my buddys code reader and it gave a P304 error code and a P0011 error code. I have it in the driveway and it will start and idle at 1000 but the second i put it in drive it drops below 500Rpms and bobs up and down and eventually dies. Any advice would be helpful because i know very little about cars. Thanks
Old Apr 10, 2018 | 04:56 PM
Jeffs02rwdSS's Avatar
P0011 is the cam position sensor Timing over advanced or system performance bank 1 and P0304 is cylinder # 4 misfire . Found a valuable link on a post from this site has all trouble codes https://www.obd-codes.com/trouble_codes/ It should give you a starting point. Can't remember who posted it to give them credit .
