Engine light
Old Jan 6, 2010 | 07:54 PM
suburbiangiant's Avatar
Default Engine light
I had my engine light come today on my 2002 SS. I had the code read and discovered it was a faulty gas cap. Turned out it was just my gas cap not tightened on. So I've got the problem resolved. My question is how long does it take for the code to clear and the check engine light to go out? It will clear on it's own right?
Thx
Mike
Old Jan 6, 2010 | 08:10 PM
you can unplug the battery for 30 seconds then that will clear the codes.
Otherwise it's like 50 starts.
Old Jan 6, 2010 | 09:38 PM
Wow that takes a while. I guess I'll pull the battery cable for a few. Thanks!
Old Jan 6, 2010 | 09:52 PM
seawolf18's Avatar
Pulling the battery cable on a OBD II system will not clear the codes like the older cars. You can clear the codes with a code reader/scan tool, or if the condition doesn't repeat in a cretin amount of key cycles(I don't remember how many) it will go off also. i would just go to your nearest autozone, or local parts store that has a scan tool and delete the codes.
Old Jan 7, 2010 | 08:08 AM
Sure it will. It's a reset to the PCM which is what stores the codes.
hotrodharley
Nov 15, 2013 11:37 AM
moemusic
Mar 16, 2011 04:26 PM
Mex24x
29
Feb 17, 2010 12:35 PM
gohawk72
Oct 2, 2009 02:14 PM
mikeymontecarlo
May 1, 2008 02:41 PM
